Subscription plan
Hiro122
Hello,
I am a current Public Mobile user but interested in 3GB for $21 plan that is available for new activations.
In this case, should I change the carrier once and come back to Public Mobile again?
or is there a way I can get $21/month plan without changing carriers?
@Hiro122 wrote:
Thank you! I will contact an agent.
@Hiro122
FYI, if you are downgrading your plan, the likelihood is low for CSA to grant the request.  For example, if you are on a plan $25+ and downgrading to $21 plan, the odds are quite low.
Even $15 plan customers have been rejected by CSA.  YMMV.  It does not hurt to try though.
Hiro122
A customers support agent might do if you ask for the plan, but if they say no, a new account would need to be activated to get the $21 per 30 days plan.
