Subscription not avtivated
Baron1
I filled out all the forms for the transfer and then it says this. What do I do in this situation?
You can check to see if the QR code went to junk or spam folder.
If its not there, you'd need to message support.
Baron1
Do you know what to do in this situation? I did not receive a QR code for an eSIM whatsoever and the support is extremely unreliable.
TheSterlinger
It's a common issue. Did you use the app to create your account?
You can contact support at the link for further help below.
https://widget.telus.tiia.ai/publicmobile/publicmobile.html.
If  that doesnt work for you then cause the next link.
