Subscription not activated
rasikashouche10
Unable to activate the subscription and transfer sim.
Frank52
Please review this article to make sure you followed all the correct steps:
https://www.publicmobile.ca/en/get-help/articles/transfer-your-number
trysten
Im having the same issue when trying to activate my subscription, and they already took my payment but i cant get service. this is crazy
hi @rasikashouche10
try reboot the phone and login to app again and see if you can complete the subscription
and if you are activating eSIM, can you double check if the PM  eSIM is already showing up on your Sim Manager or Settings-> Ceulluar?
if yes, then you need to manually enable it
if not, ask PM support agent to help, you can submit  ticket by direct message:
