Subscription not activated
charlestsang
I paid for subscription already but on my phone it says subscription not activated when i try to do it on the app. It's been few days since I have contacted supported and no one has responded. Any help is appreciated.
1 REPLY 1
hi @charlestsang did you check your community inbox ?
agent usually reply quick, like 2 to 4 hours. Message them again
and did you activate physical or eSIM?
