Subscription not activated
MrsK
I was following the steps and selected port a number from Koodo and got this message:  Subscription not activated.
It says to contact support.  I tried and I keep going around in a circle with no resolution.
Can someone explain the next step please?
MrsK
So the problem is, I chose the option to port my Koodo number. I failed to notice it’s for prepaid and not monthly customers.  I cannot go back and change my selection.
hairbag1
@MrsK
is your old Kodoo account a prepaid account ?
Transferring a Phone Number from Koodo Prepaid
If you wish to transfer an existing numbering from Koodo Prepaid, you will need to first complete your activation with a new number, then reach out to our Customer Support Agents here in order to transfer your existing number to Public Mobile.
Use the link supplied by @will13am  instead of this link.
MrsK
I was using the App.
will13am
@MrsK , did you perform the activation on a browser or app?  Activations must be completed using the app.  Support can be contacted using the link below.
