Subscription not activated in app.
Nathan19
SUBSCRIPTION NOT ACTIVATED Something didn't go right while activating your subscription. Click below to contact a customer support agent. Is the error message i get at the end of self setup in the app. Reinstalling app did not help. Reached out for support on twitter ('x') and was redirected here @CS_Agent was mentioned to direct message but not sure how to do that
@Nathan19
try this:
pressing 'Log out' in the top Left, than signing back in again after about 15 minutes.  Then log in again, for 2FA , it sends a code to the Email again, once you enter it and continue you'll be prompted to the 'Confirm for Full Access' and your Activation will be completed.
if same, please submit a ticket with CS Agent here:
HALIMACS
To contact a Customer Support Agent, send a private message to them by clicking here.  You’ll need to be logged into your Community account for the link to work.
Watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar, or tap your Avatar down in Messages.
hairbag1
@Nathan19
use this link to message a Customer Support Agent.
watch for their reply when the little envelop icon on top right side of page is highlighted.
