Subscription malfunction
11-30-2024 11:07 AM
Hello,
Long term customer [6 years]
For the first time my monthly data had reached maximum 50 GB and the unlimited data feature if my plan did not activate.
I presently have no data on this phone.
I don't see any way to activate this part of the plan.
Plans
11-30-2024 11:27 AM
Is your plan a 4G speed plan? Unlimited data is not included unless it's 5G.
If you've confirmed that you're on a 5G speed plan then it's possible the unlimited data is too slow for what you're trying to do.
11-30-2024 11:20 AM - edited 11-30-2024 11:21 AM
@Bache24 You didn't mention that you were on the Canada plan, that is why we mentioned it just in case as others erroneously thought the Can/US plan had it too. As noted above for assistance contact customer service here:
11-30-2024 11:18 AM
I already mentioned I'm on the unlimited data plan for Canada. Yes, I'm aware it's slow. The difference between 0 kb/s and 250kb/s there is 0 data connection.
11-30-2024 11:12 AM
@Bache24, to clarify do you have the Canada only with 50GB unlimited (throttled) data or do you have the Canada/US 50GB plan? The 2 plans differ in this respect so if you have the Canada only the unlimited part should be on automatically I believe
11-30-2024 11:12 AM - edited 11-30-2024 11:14 AM
@Bache24 What plan are you on? You can message support at the link below for help.
Edit: As @eddieO said below, it should happen automatically if you are on the Can only plan. It will be super slow though....
