06-01-2023 07:05 PM
Hi all,
I have a question about my subscription. I believe it's grandfathered but not sure. Currently I have:
- $105/90 days
- 1.5GB @ 3G speed/90 days
- Unlimited canada-wide talk/text
- Unlimited international text
I was checking plans out of the blue today (when for the first time I ran out of data) and found this one:
- $39/month (no option for 90 days I see)
- 20GB @ 4G speed
- Same as above can/intl
So for $4/month more than what I currently pay, I'd be getting 18.5GB extra data. I think the answer is 'duh" but I want to make sure I won't lose any of the perks I currently have? I get quite a lot taken off each month for loyalty/auto-pay.
Is this package only for a short time then the price goes up? Will I lose my perks?
Thank you 🙂
Plans
06-01-2023 07:38 PM
@Brilliance Hahahahhahahaha I hear you n me both 😉
06-01-2023 07:32 PM
@Brilliance Next time you see a plan that tickles your fancy … just schedule plan change for next renewal … screen shot it … so if it is gone and auto pay fails … you have proof for support
06-01-2023 07:28 PM - edited 06-01-2023 07:28 PM
@Brilliance There no expiry date on the promo plans … so get them while you can
06-01-2023 07:28 PM
in summary
- $2 Autopay is no longer there and replaced with 5% , you get less (but you get 5% for your other Add-on purchases as well)
- No more Loyalty reward, so no more $1/month up to $5/month. Instead, they only give $10 every year on the anniversary.
So, for someone with PM between 13th to 24th months:
old reward program will get $12 on that year compare with $10 on the new system
So, for someone with PM between 25th to 36th months:
old reward program will get $24 on that year compare with $10 on the new system
for someone with PM between 61th and 72th month (and same after this point)
old reward program will get $60/year compare with $10/year on the new system - You can no longer apply $1 or $2 you got to the bill right a way, you have to collect enough to 15 points to cash out $15 in one shot
On the other hand, the goodies for new system,
- 5% Points back for add-on purchases as well
- add-ons are around 33% cheaper when you redeem with Public Points
- you can use 1 point for lucky draw, so, technically you bet $1 and can win an iPhone
06-01-2023 07:24 PM
@Brilliance Your absolutely rights there are pros and cons … and infact if you ask @softech nicely enough he’s has a excellent brake down of the two systems
06-01-2023 07:22 PM
@Brilliance the friend rewards is the same on both old and new system. $10 to the newly joined and $1/1 point for the one refer friends
06-01-2023 07:18 PM
@Brilliance Hymm , well maybe I’m wrong , but your the first I heard promoting the points system .. all good thou .. we all know PM rocks either way
06-01-2023 07:17 PM
Ok will do! Thank you
06-01-2023 07:17 PM
@Brilliance , I would trade someone my points account for their rewards account in a heartbeat! 🤣 I miss the old rewards!
06-01-2023 07:17 PM
@KatieF Change plan for next renewal , not immediately or you lose money
06-01-2023 07:16 PM
Thank you for all the replies! Switching now! So glad I saw this one.
06-01-2023 07:14 PM - edited 06-01-2023 07:15 PM
@Brilliance You sure ? … check out my first post ….
@KatieF don’t ever switch to the new points rewards there not nearly as lucrative as your old rewards system
06-01-2023 07:11 PM
@KatieF limited time offer but not limited pricing. Once you are in, you are in
so, get it while you can. Yes. It is a great deal
06-01-2023 07:07 PM - edited 06-01-2023 07:08 PM
@KatieF Yes you get to keep your old rewards no worry .. I just did this plan change my self check it out 😉
Add the plan dosent expire either
