Subscription Not Activated (Porting Number + eSim)
MargaretC
Hello,
I'm porting a number and eSim over from another providor and I had an issue activating my subscription. Logging out of and back into the app doesn't restart the process, it just says I have to contact support.
Help?
MargaretC
Ah — Looks like PublicMobile CS_Agent is on it!! Just got a DM.
MargaretC
iPhone 12 Pro.
Got past all the info steps. It was downloading the eSim — but ended in Subscription Not Activated screen.
Settings -> General -> About -> eSim
Shows my previous carrier using eSim installed.
@MargaretC
You already got passed the step to provide the porting info and you are at Step 6 of the Subscription process?
First, are you using iPhone or Android?
Please check your Settings> Cellular screen (on iPhone) or Sim Manager (on Android) to confirm if the Public Mobile sim is there and enabled.
