Subscription Effective Dates
pbudreski
A question in connection with subscription change. Currently have a package that has 50 GB data that renews on 10th. If I change to subscription to 100 GB on 15th, is that the date it is effective? How long does updated subscription last for?
2 REPLIES 2
Meow
If you force subscription to start on 15th then that will be your billing date (minus few days as year progresses due to 30 days billing period).
BUT you will be immediately charged thus losing 25 days of 50GB subscription.
Better way to change subscription is to Schedule plan change on NEXT renewal. That way you will use your 50GB plan for the rest of period, on 10th you will be switched to 100GB plan and charged for it.
SKSuh
It is more cost effective to have the subscription change take effect on your next renewal date so that you aren’t forfeiting your last payment
An updated subscription will remain in effect until you change the plan in the future
