30 d 3gb usage increase $5
Casi0508
Hello why there is an increase in my subscription effective Aug bill. Pls advise. Thank you
11 REPLIES 11
@Casi0508 wrote:
My Samsung model a3 typo error not s3. Pls advise
Galaxy A3?  A3 was a phone from 2014 and it has no VoLTE at all.  The phone will no longer work on any network once 3G is fully decommissioned
@Casi0508
Yes until March 1/27. It is 8 months away so you will be paying a total of $40 which you can put into a new phone. After that you phone will can’t make calls.
Casi0508
Okay thank you for the info. However if my phone Samsung S2 not compatible. Every month there will be a $5 surcharge.
Casi0508
Casi0508
Hello my Sa msung model S3 bought year 2021. What now that means my voicemail will be gone. Pls advise
@Casi0508 wrote:
The other phone which my wife uses I moto g play 2024. Pls advise. Thank you
@Casi0508
the Moto G Play 2024 has VoLTE and is compatible with PM's VoLTE network
@Casi0508
The Samsung A02 is not fully VoLTE compatible on PM network.
https://www.google.com/search?q=is+the+samsung+a02+volte.compatible.on+public+mobile+network%3F&rlz=...
You need to get a newer phone.
hi @Casi0508
While your Samsung Galaxy A02  has VoLTE, it is NOT compatible with PM's VoLTE network.  You can use the  IMEI checker on this page to confirm:  https://www.publicmobile.ca/en/on/get-help/articles/volte
There is really nothing much you can do other than to get a phone that is compatible with PM's VoLTE network.
Casi0508
Casi0508
My phone is Samsung Galaxy a02
@Casi0508
the plan price itself didn't change, but ou have been hit with a $5 surcharge for using a device that is not VoLTE compatible with PM network.   The charge is only meant to encourage you to get a new and compatible device as PM will be retiring 3G network.   Once you have a new VoLTE compatible phone, the $5 surcharge will be removed.  However, if you do nothing and just paying the $5 surcharge, you will not have any voice service once PM retires 3G network in March 2027.
Let's try to confirm what phone you have and how to have this charge removed with a compatible phone
What phone do you have? Which province you are in?
First, use the IMEI checker on this page to see if your phone is compatible with PM's VoLTE network:  https://www.publicmobile.ca/en/on/get-help/articles/volte
If it is not compatible with PM's VoLTE, then your phone had been using 3G for voice and is now affected by the 3G Network Shutdown that has just started in Manitoba:
https://www.publicmobile.ca/en/get-help/articles/3g-shutdown
If you’re using a 3G-only device, your phone will stop working after these dates:
Manitoba (Rural): January 12, 2026
Manitoba (Urban : Winnipeg & Brandon): Starting March 31, 2026
National: Starting March 1, 2027
If the lack of VoLTE support is what affecting your voice calls, there is really nothing much you can do other than getting a phone that is compatible with PM's VoLTE network.   Hare are couple choices that will work:
  • iPhone 8 or later
  • Google Pixel 4 or later
  • Samsung S22 or later
  • Samsung Flip 2/Fold 2 or later
  • Samsung A15/A35/A55 or later
But generally most major brands of phones released after 2024 and are designed and sold for the Canadian market should work.  ( BUT Imported phones/grey market phones sold on marketplaces likely won't work)
If you are unsure whether a particular phone will work, share the model here and we can help
