05-08-2025 01:07 PM
Hi there
I changed my subscription at the end of April. It started change from May 1st.
Unfortunately, my data is not working when i turn it on. Also incoming calls show call id as UNKNOWN.
It has been a trouble for me. I can not get uber to go home from work because there is no data.
Also i ve no idea family member or who is calling me when it rings.
Please help me,
Thanks
Ana
05-08-2025 01:20 PM
Thanks Handy1 for reply. Yes i mean my save contact numbers. It does not show it. I ll try find my apn setting. I should go to work now. I m afternoon worker. But i will check it by tomorrow. Thanks for help.
05-08-2025 01:17 PM
Hi slusagm, thanks for reply i follow link
05-08-2025 01:10 PM
so many complain data stops working after plan change. You will need PM to refresh account
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
05-08-2025 01:10 PM
hi @Ana90
what phone do you have?
try Reboot phone and Reset All networks and check
if same, then submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
05-08-2025 01:09 PM
@Ana90 There’s no caller ID with public mobile just shows the phone number unless you have those callers in your contact list as for dat ensure your APN seething are as follows
APN settings
