Subscribing
C-Rock
Have a previous log in account. Trying to subscribe but it takes me to a previous plan that i don’t want and can’t change it..What do i do. I did go through process but then eSIM issues.. any ideas on what to do
C-Rock1
Thanks for help
salah99
same issue. Sent a msg to the the ticketing system via: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage in the to field use 'CS_AGENT' though.
you might need PM to sort it out
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
C-Rock
When i log in it goes directly to complete subscription which is the Can-US plan and doesn’t give me a option to back out or change.. only option was to proceed or log out
slusagm
So, you left PM and came back?
what previous plan you see? if you are logged in to a My Account, do you see Change Subscription link?
