Subsciption addition
Harpua
Hi,
I would like to add a subscription to my account not change my current subscription but the user interface makes it impossible. How is this accomplished?
2 REPLIES 2
@Harpua
Do you mean that you want to purchase an Add-on for additional minutes, data, LD calling or Roaming?
You will need to login to your account and go to Add-on.
If you have difficulty in login to your account. If you are a longtime member, did you create a Eversafe ID before trying to login? Click on Sign Up before login if you haven’t created an ID.
If you are still having problems login. Contact a CS_Agent to help you login to your account by private messaging at:
@Harpua  If you want a second account you have to create a new account with a new email . You can only have one phone number per account with its own email . So create a second  account with a new email and be sure to use your referral code when activating it
