Stingers (devices used to intercept or monitor phone conversations)
CellphoneuserPM
I am interested in knowning if anyone knows what my option are for a Stinger? Thisis a device that can monitor or intercept phone calls.  Located in Canada, Ontario, brampton on Candlewood crt.
Do I have any options for having any resource investigate ? I have already spoken to Publicc mobile and they only provide service
PAULRANG18
This is a matter that PM would not want to be associated with. I believe community members would agree.
@Lemony_Snicket wrote:
Maybe try the RCMP or CSIS.  Surveillance systems have nothing to do with Public Mobile.
Oh to be listening on speakerphone on that call. 🙂
OP: do you really think you can waltz into your local Walmart and pick up a surveillance tool to listen in on people and invade their privacy? Try the "dark web" like in the movies. Not here.
Lemony_Snicket
ChuckYeah
That sounds illegal, isn't it? If so, you should probably remove that from this forum. I assume it would fall outside of the terms of service. Or are you trying to defend against such devices?
