2 weeks ago
I HAVE sufficient funds in my account but receive a Payment Failed message when I try to buy data
2 weeks ago
@Richard64 , try using incognito mode when accessing your online account. That might help as data caching problems can affect the online account. BTW, what plan are you on that would require the purchase of add-on data? Add-on data is expensive and no longer non expiring while plans with a good amount of data has dropped significantly in cost.
2 weeks ago
where you using the browser to buy addon or app?
Try again:
If issue persists, you might want to open ticket with PM support. They can likely help to make the purchase as you have enough fund there already
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗"
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
