02-14-2026 06:59 PM
Is the 25$ the same as 26$ but just1$ less and I’m still deciding if I want to upgrade to 10go for 27$ or get the 25$ offer what should I do?
02-14-2026 07:22 PM
if you usually run outta data before your regular plan renewal...best to take the plan with more data. If you don't usually use all your current data...just leave that extra $$ in your pocket for something you can use. Like Tim's coffee maybe !
02-14-2026 07:13 PM
02-14-2026 07:10 PM
this is my current one and I still haven’t decided if I keep the same one or if I go for one of those 2
02-14-2026 07:04 PM
$2 for 5 extra GB's data...go for the $27 if you use that data.
02-14-2026 07:03 PM
Where you see the $26 plan? But yes,, those plans are same just the difference in data amount, you get the same service features
