Sos only
Vic902
Hello everyone
can someone help me, my phone for the past few days is showing sos only.
my bill is paid and phone is working/setup correctly, even tried with my husbands public sim and his sim works fine in my phone
has the sim died for some reason?
thanks
lunnenlen
Have tried going to your network settings and manually selecting a network?
Vic902
Thanks I have sent a pm
@Vic902  No worry’s support can help
send  a  private message   To CS_Agent
hi @Vic902
so, did you try sim in another phone?
and if you need PM to check, please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
