So Frustrated
Mggordon
I cannot sign into my account to update my credit card info. I need to pay my bill in the next 24 hours or I am assuming my phone plan will not longer work. I have reset my password a number of times. When I go to sign in following, it says my username/password are incorrect. It has locked me out numerous times. I am now locked out for yet another time period- 3 hours this time.
My sister is having the exact same issue!
How on earth can I update my info when there’s no way to get into my account?
7 REPLIES 7
ZuckMark
This is not a bill, its just a PREPAID service and you can Top Up with a voucher.
Mggordon
Thank you for providing so much information on how to stop spinning my wheels.
Mggordon
Will try that. Thank you
Hi @Mggordon try again  on a desktop computer
Mggordon
I am trying to update my expiration date as I have a new credit card. I have always had it set up to have automatic payments. I have done the completely different password and it did the same thing?
Hi @Mggordon  did you try using Incognito mode to try another browser like Edge or Firefox?
if still not working,  I think you need to open ticket with CS agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. start by typing : Contact CS Agent
  2. then Click "Contact Us"
  3. then Click "Other"
  4. finally Click "Click here to submit a ticket"
NDesai
@Mggordon Try reseting your password again and change it to something completely different. Then try logging in using incognito/private browsing mode. Alternatively, you can purchase PM vouchers from stores or online and dial 611 to redeem. I recommend you have a credit card added with Authorized Payment enabled. This way it will charge you automatically or you can manually add payment by calling 611 if AutoPay is disabled.
