Sms
Rayandiab
Can't send recove sms
HI @Rayandiab
it could be just a problem with the message app.  First uninstall Google Message, then reboot phone and restall and set it as the default message app and try text
different samsung phone (with different OS version) could have it slightly different, but you can try
  1. Open Settings
  2. Select General management
  3. Select Reset
  4. Select Reset network settings
  5. Select Reset settings
Rayandiab
I did reboot , it didn't work.  Data and calls are working OK
Rayandiab
How do you reset network setting! I have samsung phone
slusagm
new account? did you remove the sim card from the old provider (or disable the esim)?  then reset network settings and should work
if iPhone, there is a chance you need to register number with iMessage again if you just ported in your number
eddieO
@Rayandiab first thing I would try is rebooting your phone, lots if times this will do the trick. Does data and voice calls work? Do you have another phone that you can try your SIM card in?
