Sms not working
TimeAttack
Its been over 5 hours, can you send the sms activation  again
@CS_Agent
2 REPLIES 2
@TimeAttack
If you are porting to PM. Contact a CS_Agent to restart the porting process. Keep your old SIM in your phone and wait for the text and reply with YES…you have 90 minutes to reply.
Private message them at:
If you are porting out, you need contact the new carrier to restart the porting process.
@TimeAttack  did you down load the app to activate ? try rebooting the phone or reset network settings .if you need customer support here’s the link
private message   To CS_Agents click
