5 hours ago
4 hours ago
hi @Jord09 is that an iPhone?
4 hours ago
Activation required is what it is saying
4 hours ago
Activation required is what the phone says
4 hours ago
hi @Jord09 as long as the sim fits, it is probably not a sim card problem but phone
what model is the phone? maybe it is not compatible here
does this phone work earlier? check if the phone is blacklisted or not
5 hours ago
@Jord09 Was the new phone brand new or new to you ? If you got it second hand it could be locked to another carrier also check
Check
