Sim wont work
Carinababina
I started my account yesterday.
I got an email saying welcome to Public mobile etc. and log in here.
I cannot log into my account and my sim wont work
any ideas?
Carinababina
ok thanks.
will13am
@Carinababina, unfortunately you are going to need to contact the moderator team to get support.  Their turnaround time is at least 48 hours.  The moderator team can be reached via private message using this link.  Please include in the private message account number and PIN code along with a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
Gonzo
Did you try your SIM in a different phone? Did you get the PIN confirmation text?
I might be stating the obvious, but wanted to note that the logins for this community vs. your PM account are two different things.
