Sim not working
Jessicalewisss
New sim card in but the sim number when I register says invalid
2 REPLIES 2
Meow
Did you buy SIM from legitimate source?
What do you try to accomplish? Change SIM or activate brand new account?
@Jessicalewisss   what are you trying to do with the new SIM card?  Activation or Change Sim card?
for activation, please go to https://activate.publicmobile.ca/
For change sim card on the current account, login to My Account , click Change SIM CARD and follow the steps for 2FA:
https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/change-sim-card/https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/change-sim-card/
Make sure you enter the 19 digits sim number correctly
if still fails, open a ticket to Pm to validate if the SIM is new , never used
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
