Sim not working
shams7157
I have done all the trouble shooting. It is still not working.
9 REPLIES 9
shams7157
Yes I did it through that way. I have sent a direct message. Been over 2 hours but no response.
@shams7157
You were probably using Chatbot, but Chatbot is not working.
Instead, use this link for direct message with CS agent, it will work:
shams7157
I am unable to create a ticket either. Did all the troubleshooting regarding that too. Also tried directing messaging. No response yet.
@shams7157
just want to make sure, you have used the app and got passed the phone number/porting step, right?
If you have gone all the way to step 6 on the app, then yes, sound like a sim card provisioning problem.  Easy fix for PM support but you will need to open ticket with PM support by direct message:
But if you have not used the PM app for subscription yet, then the subscription process is not completed.  You need to download Public Mobile app, login and finish the activation.
shams7157
New activation. I have tested in another phone too. Did all the trouble shooting. It says SOS.
@shams7157
new activation or existing customer?
you have another phone to test the sim card?  What exact message is that?  SOS? Sim not provisioned? or No network?
shams7157
Physical sim. iPhone.
@shams7157  Please
send  a  private message   To CS_Agents
@shams7157
physical or esim?
what phone do you have? iPhone or Android?
