10-02-2018 08:29 PM - edited 01-05-2022 05:50 AM
Hey actually I put the sim in my iphone and it perfectly had signal .. but when I put in my moms phone it doesn’t work .. it says no service .. I just got this sim and the retailer said its gud to go .. what should I do ??
10-04-2018 09:52 PM
Alright thnx bud😇
10-03-2018 12:16 AM
The version of the 4a sold in India is 100% not compatible with public mobile.
https://www.gsmarena.com/xiaomi_redmi_4a-8420.php#india
As @will13am noted, it features 900MHz and 2100MHz 3G frequencies (for use with Indian carriers), while Public Mobile (Telus) operates on 850MHz and 1900MHz. This phone will not work here. You can use it with Rogers, Fido, or Chatr until such time as Rogers shuts down their legacy 2G GSM network (I believe some time in 2020).
10-02-2018 09:50 PM
@Mankiranbahad wrote:device name- redmi model num- redmi 4a model name- 2016116
https://www.publicmobile.ca/en/on/get-started
Use the above two tools and see what you get back.
It seems likely that phone may not be compatible.
10-02-2018 09:34 PM
@Mankiranbahad wrote:its an indian phone though .. so she brought it in canada and she has no idea if its locked or not .. is there any way to know if her phone is locked or not ..? her phone is redmi and model number- redmi 4a model name - 2016116
Since the sim worked on your iPhone, there is nothing wrong with the sim or your account. I am pretty its the phone that is either not compatible or locked to another carrier.
10-02-2018 09:33 PM
The problem is with the phone. This thing does not have 850/1900 Mhz on 3G.
10-02-2018 09:32 PM
10-02-2018 09:27 PM
10-02-2018 09:26 PM
@Mankiranbahad What phone do you have and is it unlocked or locked to Telus/Koodo?
10-02-2018 09:22 PM
@Mankiranbahad, could you provide a bit more information please so we can help with troubleshooting. Did you activate yourself via the online portal or was it done at a retailer? Are you able to go into the self serve account or is that not possible.
10-02-2018 09:20 PM
no service on my phone since i got it today
10-02-2018 09:10 PM
@Mankiranbahad it's possible your mother's phone is locked to her previous provider. Or, incompatible. We can help with the compatbility question if you let us know the brand and model number (be as specific as possible), or you can check for yourself at https://www.willmyphonework.net.
10-02-2018 08:41 PM - edited 10-02-2018 09:31 PM
Like the post above, find out what phone your mom has and what bands it supports.
Then check this thread if there's any that macthes:
10-02-2018 08:34 PM
If it works in your phone but not your mom's then it's an issue with your mom's phone.
What phone is she using? Is it compatible with pm?
