Sim missing
Peter1947
I cannot connect to network esim is missing
Peter1947
There’s no sim in settings cellular
Dunkman
@Peter1947
If you don't see the eSIM in your settings, you can repurchase eSIM via your PM app.  You should not be charged again.  When you repurchase, the eSIM will be re-installed on your phone.
hi @Peter1947
did you delete the esim by mistake?
try reboot phone first, then go to Sim Manager or Settings->Cellular, let us know if the PM esim is there
