Sim isn’t working
Mmuizie
My sim has no network , and it’s written SOS what does that mean please
2 REPLIES 2
@Mmuizie  No worries support can help , easy fix just
send  a  private message   To CS_Agent
slusagm
that means the sim not connected to the network
Try to take the sim out and put it back firmly, try on another phone as well if possible
of course, check My Account to confirm if your account is active
if you need PM to help, you might need to message them as you wont be able to receive 2FA text, message them here:       https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
