04-13-2022
06:54 AM
04-13-2022
08:05 AM
computergeek541
Hi... l have used this sim card before for a few years. Cancelled it about 6 months ago and now I'm trying to register the same sim card with the same phone but it says not valid?
04-13-2022 11:37 AM
Yeah you are past the deadline, so you can use your same email to make a new account but will have to get a new sim and new number - you can try to get your old number but most likely not available anymore.
04-13-2022 09:41 AM
Once PM service is cancelled and number deleted, SIM is of no use.
You would need new SIM to create new PM account.
04-13-2022 09:09 AM
Your SIM if it was expired after 90 days so it is no good anymore.
Purchase one from CCS online for $2.99.
04-13-2022 07:25 AM
@Jimballs No, Used sim card for cancelled account cannot be reused. All sim cards can only be activated once.
So, please go to a store to get a new one for your new activation, it usually cost around $10. Or you can activate in store and they will likely give you the SIM for free
