01-23-2026
08:25 PM
01-24-2026
05:17 PM
computergeek541
Hi there,
I lost my phone and SIM card, so I need to replace it. Once I get a new SIM card, will the old SIM card be cancelled. I'm wondering if I can keep the same number, or do I have to get a new number in this situation.
Thanks for any info.
Rowan
01-24-2026 12:03 PM
@r-farnell So long as your new phone is eSIM compatible you can just log into your account and buy eSIM right away without waiting for new physical SIM card or saving yourself a trip to the store to buy
01-24-2026 11:28 AM
Thanks so much!
I'm wondering about the eSim. Do you have any information on how that works? Same cost, same process?
01-23-2026 08:38 PM
You can keep your phone number. You'll need to login and update the SIM card number on your account to the new one. For now you should login and report your phone lost so your services are temporarily disabled.
01-23-2026 08:37 PM - edited 01-23-2026 08:40 PM
@r-farnell Yes you can keep same number , but when you get new SIM card just log into your account and got to account page notice “change your SIM card “ tap it and follow the prompts and it will cancel old SIM card and you will keep same phone number and plan ,
if you have any issues just message support to help change the sim for you
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
