Sim card
11-22-2024 05:45 PM
Hello. Where can I purchase a SIM card and plan in Winnipeg. I don’t want the eSIM card
Service
11-22-2024 06:22 PM
@Windross if you order from amazon that's the cheapest option, $5 and if you have a Prime account it will be free shipping and should arrive in 1 or 2 days.
Buying from TELUS/Koodo or Mobile Klinik will cost $10 plus tax. You can also order from Public Mobile but with Canada Post on strike that probably won't be a good option. Even without the strike it was taking upwards of 2-3 weeks to arrive.
11-22-2024 05:46 PM
Hi @Windross Check if any Telus or Koodo stores close by have it. Call them and check , or order from Amazon
Telus or Koodo store https://www.publicmobile.ca/en/on/pick-up-SIM
Amazon.ca https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/
11-22-2024 05:46 PM
@Windross Any Telus or Koodo outlet should be able to help you.
