05-16-2018 09:11 PM - edited 01-05-2022 04:47 AM
I have a Alcatel PIXI 4. It is unlocked. It won't recognize my sim card. What is the problem. I just reactivated my account and put in the new sim online (lost my other phone and sim card).
05-17-2018 06:56 PM
@jblack86, You're lucky you were able to remove the SIM. I suspect that inserting the SIM with a smaller size than needed could get the SIM stuck in the phone.
05-17-2018 06:01 PM
@matbasm wrote:
@jblack86 wrote:
@will13am wrote:@jblack86, what do you mean by the phone won't recognize the SIM card? Is it not able to read it or the phone is rejecting it as an inactive SIM card? You mentioned the account has been reactivated. Is the account status active in the overview page?
It says No sim card - Emergency calls only. Account status online is active.
Any chance the SIM is not inserted correctly/using the wrong size? ...Sorry, I have to ask...
I was using the wrong size! Thank you.
05-17-2018 10:53 AM
@jblack86 wrote:I have a Alcatel PIXI 4. It is unlocked. It won't recognize my sim card. What is the problem. I just reactivated my account and put in the new sim online (lost my other phone and sim card).
Try adding scotch tape on the underside, cut to fit, and reinsert. Add a couple of more scotch tape layers and try again. If that doesn't work, you may have a defective SIM.
05-17-2018 12:56 AM - edited 05-17-2018 12:57 AM
@jblack86 Go into your phone settings, click on “About phone” and provide the exact model of your phone, so that we can check if your model is compatible with Public Mobile or not.
Thank you! ![]()
05-16-2018 10:05 PM
05-16-2018 10:03 PM
@matbasm wrote:@jblack86, Is the PIXI 4 a new phone you are using, or did you use it with your previous SIM card. From what I can tell on WillMyPhoneWork.net, there are several variants of that model. Only one of them is fully compatible with Public Mobile.
It must not be compatible that's the only thing I can think of.
05-16-2018 10:02 PM
New pixi 4 i'm using. Retailer said it was compatible.
05-16-2018 09:59 PM
05-16-2018 09:59 PM
05-16-2018 09:54 PM
05-16-2018 09:14 PM
I recommend you send a private message to the moderator team and ask them to investigate. include your account# or phone#, as well as your account PIN (if know) to help speed up the identification process.
Click here to send the moderator team a private message.
You can find information regarding the moderator team by following this link.
How long until a moderator replies?:
How can I view my private messages between myself and a Community Moderator?
