Sim card turning on and off
01-19-2024
08:42 PM
01-19-2024
08:49 PM
computergeek541
Ever since I switched over and cancelled my old plan, the sim card keeps switching on and off constantly. (E.g It shows full bars then no bars constantly). Meaning I have no access to data, calling, or messaging. I have changed my APN, reset all my networks, followed every page. How do I reset my sim or do anything to fix this and have a working sim??
Service
01-20-2024 07:05 AM
@Emma163 wrote:Any other suggestions?
Methodical troubleshooting.
Observe others using their phones around you. If their Telus/Koodo/Public/Bell/Virgin/Lucky service seems to work fine while yours doesn't then the problem is not the local network.
Try shaking your phone. See if it's some kind of internal hardware problem - faults like a loose antennae or intermittent electrical contact or bad solder point don't have to actually make a loose or rattling noise.
Check your battery when your signal fails. It could be dying - the electrochemistry could be degraded - even when it reports full charge to the software.
01-19-2024 09:29 PM
@Emma163 You can ask support to refresh your account and see if that helps
send a private message To CS_Agents
01-19-2024 09:16 PM
It is an esim, and just before switching plans my phone sim was working fine. I don't think it's a device issue and it's also an esim so not sure. Any other suggestions?
01-19-2024 08:58 PM - edited 01-19-2024 08:59 PM
@Emma163 wrote:Ever since I switched over and cancelled my old plan, the sim card keeps switching on and off constantly. (E.g It shows full bars then no bars constantly). Meaning I have no access to data, calling, or messaging. I have changed my APN, reset all my networks, followed every page. How do I reset my sim or do anything to fix this and have a working sim??
This isn't a phone setting issue. Specifically, APN settings are unrelated to the base conection to the cellular network.
01-19-2024 08:45 PM
@Emma163 Is it a physical SIM card ? If so can you try it in another phone to test ? And possibly if you can try another known to work SIM card from a from family or friend and try it in your phone ? This will help determine if it’s a SIM card / account issue or a device issue
