06-16-2025 01:17 PM
Does anyone know how to tranfers my Public plan and phone number to a newer phone . The sim car I ahve in my old phone does not fit in the new phone.
The new phone is using nono Sim
06-16-2025 01:33 PM
@LeoRich wrote:Does anyone know how to tranfers my Public plan and phone number to a newer phone . The sim car I ahve in my old phone does not fit in the new phone.
Hello @LeoRich
As already mentioned about the SIM card sizes, I'll throw another option for you. Depending on your new phone, it might have eSIM capabilities. If it does, all you have to do with your new phone is to download the app, purchase an eSIM for $5 and install it. Then, any time you get a new phone, your future eSIM's are free. Best part, it leaves the SIM slot open for other SIM cards foreign or domestic.
06-16-2025 01:20 PM - edited 06-16-2025 01:26 PM
hi @LeoRich
your sim card should look like this:
you should be able to snap out the frames and make it nano size, the size for all current phones
but if you need a new Public Mobile sim card, buy it from Telus or Koodo or MobileKlink for $10 or buy from Amazon for $5 (https://www.amazon.ca/Public-Mobile-Unlocked-Canadas-Subscription/dp/B0CD896ZZH)
then login My Account and go to Profile and update the sim card number there, and then reboot the phone
06-16-2025 01:19 PM - edited 06-16-2025 01:23 PM
the PM sim cards are pre-cut with the differen sizes. If you look carefully, you can remove the outer rim to make it smaller and fits your new phone
