09-21-2024
08:44 PM
09-21-2024
08:50 PM
computergeek541
09-21-2024 10:26 PM - edited 09-21-2024 10:27 PM
@Al_433 wrote:Will my sim card for a Note 9 fit a Pixel 8A
When you originally got your SIM card, it could pop out of the full size "card" into 3 different size sim cards. See below the Grey (Standard), Blue (Micro), and Yellow (Nano). If your previous phone used the "Micro" size, you can still pop it out further down to the "Nano" size for your new phone, and vice versa if you still keep the plastic frame to go back to the larger size.
Edit: But I see as @computergeek541 has already mentioned, he has identified that both of the phones you indicated already use Nano sim, so I guess you can disregard this. 😝
09-21-2024 08:50 PM
Yes, it would work as both use nano SIM.
