Signal poor
K-13
My cell signal has been awful lately. I live at the south end of Georgian Bay. I can text but having conversations has been awful. Thankfully I still have a landline but my cell phone is my work number. Anyone else having issues?
Nezgar
Can you confirm that your phone is staying on the LTE network while on a phone call (confirming VoLTE is in use).
As a workaround for now to not miss or drop important at least incoming calls, you can forward to your landline with *21*xxxyyyzzzz# and unforward with ##21#.
K-13
Thanks, I will give that a try.
hi @K-13
with iPhone 13, you should not be impacted by the recent change
Try Reboot phone and  Reset Network Settings on your phone and check if it works
K-13
Just voice.
I have an iPhone 13
hi @K-13
what phone do you have?
is it just voice issue or data is bad too?
if it is just voice, it could be something to do with PM's system change on 3G network and your phone is not capable of using VoLTE on PM's network.
