Signal network
Eddlyn
I did all the trouble shooting that PM provide me to do, but still it doesnt work! it shows emergency calls only sometimes have signal but usually no signal i experiemce more than a week. How to fix this somebody to help?or else i will cancel/unsubcribed to this provider
2 REPLIES 2
Phil_Adelphus
@Eddlyn   If you do decide to go to another provider, you still need to have your Public Mobile account active if you want to keep your number.  If you cancel/unsubscribe before porting out you will not be able to receive the SMS from Public Mobile to authorize the transfer of your current phone number
funpig1
