Signal drop
_best
Hi PM, I'm having issues wit the PM network again. The phone signal keeps dropped. Please repair.
_best
Switched to 3g on the phone.It's working fine thanks for your help
Michael77
Do you have the issue when your outside or is the issue only happening indoors?
will13am
There should not be a need to force the phone onto 3G, unless it was set to strictly use LTE.  The best solution is to selecte LTE preferred so that if the LTE signal is weak, then the phone will auto negotiate to 3G.
mimmo
Have you tried your sim in a different phone? This will isolate sim issue vs phone issue.
_best
I'm in the same location were I always use my phone. I'll try forcing the phone to 3g
Luddite
Where are you? Is a problem in many locations or just a few?
What is make/model of your phone?
Try forcing the phone to 3G instead of LTE/Auto.
