05-29-2019 10:30 AM - edited 01-05-2022 05:08 AM
Not my account, but my friend added the $15/400 minutes to their publicmobile account, and it seemed to give them $15 worth of credit, but it doesnt list anything about USA calling under "My plan".
Should it be listed there??
This was done yesterday.
Thanks
05-29-2019 10:39 AM
@Anonymous wrote:
@thegman wrote:Not my account, but my friend added the $15/400 minutes to their publicmobile account, and it seemed to give them $15 worth of credit, but it doesnt list anything about USA calling under "My plan".
Thanks
That's the first step of 2. Now you need to actually buy the add-on.
If you're just calling to the US on occassion then you might prefer the $8 add-on.
If you're intending to use service while IN the states then you need to buy roaming add-ons.
When successful you'll see add-ons under the data & add-ons area.
Thank you! Yep, that did it, now the plan is added and shows up under My Plans!
Thanks!
05-29-2019 10:32 AM - edited 05-29-2019 10:33 AM
Thanks
