Setting up Voicemail
ecowen
I followed the instructions for voicemail setup, however I am unable to figure our what my "box" number is, or if I even need one.
1 REPLY 1
dabr
Do you mean your 'mailbox' number?
That will be your phone number which would be the default setting if you haven't set up your voicemail to use your name instead.
