09-19-2022 07:15 PM
Hello. My account is renewed today. I upgrade my plan. I can call someone but I can’t receive any calls. The data service is also not working. Tried resetting the network and turn on or off the device. Nothing seems to work.
09-19-2022 09:37 PM
09-19-2022 07:20 PM
Hmm, that's strange. Usually if you run out of minutes, they still let you accept incoming calls, but it doesn't sound as if that's your problem since the plan just renewed today.
09-19-2022 07:17 PM
hi there have been issues the last couple of days with plan changes meesing up , you need to contact customer service agent to fix it for you
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
09-19-2022 07:16 PM - edited 09-19-2022 11:00 PM
There have been issues last few days. Contact an agent.
During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
Keep an eye on the envelope icon in top right hand corner for a reply from the agent.
