10-10-2025 10:58 AM
Hi there,
I recently find that I can't make calls but can receive calls.
Can you help me check and solve this problems?
Thanks.
10-10-2025 11:20 AM
I just reset networking settings but it's still the same
10-10-2025 11:12 AM
I found this issue since this Monday.
10-10-2025 11:08 AM
how recent you have the call issue? if just since yesterday, check the Telus Outage map, there are lots of Mobile issue in Alberta and Vancouver area
10-10-2025 11:02 AM
hi @Daisyppwang
iPhone 16 is safe
just make sure you are on latest iOS, and have the latest Carrier Profile
Then click Reset network settings and test again
if same, ask PM to refresh account on the system. You can submit ticket by direct message:
10-10-2025 11:00 AM
I use iPhone 16 pm
10-10-2025 10:59 AM - edited 10-10-2025 11:01 AM
hi @Daisyppwang
what phone do you have?
Telus is refarming all of their 850 to 10 MHz LTE B5 in their markets, mainly BC, AB, Windsor, Ottawa, GTA area Montreal, Quebec City. Bell has not done this, so it won't affect area that has Bell networks which Telus/PM use
If you phone has VoLTE and is compatible with PM VoLTE, you shouldn't be impacted at all. Check here:
https://www.publicmobile.ca/en/get-help/articles/volte
But if your phone is not not on PM's VoLTE whitelist, and if your phone has only 850 Band 5 on the phone but lacks 1900 Mhz, if your phone were bought from another country, or an imported model, then you might be impacted with no 3G voice service at all
On the other hand, if the phone has 1900 Mhz, or it is a Canadian/US model, it likely won't be impacted as much but the voice calls quality might still degraded.
https://www.publicmobile.ca/en/get-help/articles/850-turndown
