Service is not working
Soong87
I need to speak a live agent asap.  Thank you
2 REPLIES 2
slusagm
@Soong87
new activation? and what phone you have?
Reboot phone and Reset network settings and it should work
also check My Account to see if account is active
last, you can open ticket with PM.   Assuming you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
Meow
Open a ticket through chatbot.
PM does NOT have live support.
