02-24-2020 05:22 PM - edited 01-05-2022 09:38 AM
24 hrs ago I added unlimited text, call and 250mb of data to my plan. However still all text sent to a US number does not get delivered. My phone is showing T-Mobile and I did reboot my phone
02-24-2020 06:21 PM
@Devsan wrote:Had to turn on SMS on my iPhone.
Gosh, I would not have realized what to do,
many thanks everyone for their input and guidance. Much appreciated.
Back in Canada, I was receiving text messages I'm guessing even when my SMS was off? Getting too techy for me!🤔
That's the precious little Apple world wanting to keep you all to themselves. iMessage is really more of the old style instant messaging. Only it's only between iPhones. It works on wifi and cell data.
02-24-2020 06:15 PM
02-24-2020 05:48 PM
@Devsan wrote:Aha...did not realize I had to manually enable data roaming. So let me try that and hopefully it works.
How do I manually set carrier to AT&T?
@Devsan Roaming only applies to data but if you are using an iPhone and iMessage it could allow the texts to go out and resolve your problem if iMessage requires data.
02-24-2020 05:43 PM - edited 02-24-2020 05:46 PM
@Devsan try enabling roaming, restarting and texting with t mobile first.
If that doesn't work Android phone - settings - network & internet - mobile network-at&t. Restart again.
02-24-2020 05:42 PM - edited 02-24-2020 05:43 PM
@Devsan wrote:24 hrs ago I added unlimited text, call and 250mb of data to my plan. However still all text sent to a US number does not get delivered. My phone is showing T-Mobile and I did reboot my phone
@Devsan Can you make calls? Does data work? If yes, then it's not an add-on issue. What type of a phone are you using. If Android force close the messaging app and restart your phone. If you have an iPhone make sure SMS is turned on or disable iMesssge.
02-24-2020 05:39 PM
02-24-2020 05:36 PM
@Devsan If nothing helped, you can send a message direct message to moderators so they could investigate your case and resolve it by, for instance, restarting your acount on their system: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
02-24-2020 05:35 PM
Just one number?
What is the area code and prefix you're trying to text? (don't post the 4 digits)
02-24-2020 05:31 PM
02-24-2020 05:29 PM
@gblackma wrote:@Devsan are you in Canada or the US? Thanks.
Uhm..... I think the answer to that question is probably in the title of the thread.....
02-24-2020 05:28 PM
Yes
02-24-2020 05:28 PM
In US
02-24-2020 05:27 PM
02-24-2020 05:24 PM
02-24-2020 05:23 PM
Try manually changing network to Att
