Sending and Receiving texts are delayed
mahadeotahal
I cant send texts - they seem to linger there for hours. Sometimes they clear, especially if I reboot. The same for receipt but not to the same extent. Any suggestions? Its very frustrating.
2 REPLIES 2
hss
Might be just your Phone settings. Try resetting the phone and message settings and reboot the phone. Or just reset the whole phone if you got a backup.
popping
@mahadeotahal
Can you browse internet on mobile data?
If not, your APN settings is not right.
Try the simple procedure first by enable data and restart your phone to let PM SIM card to configure your APN settings automatically.
If you have a LG phone, you need to do a network reset after switching provider before your mobile data start wortking again.
