07-22-2026
07:16 AM
07-22-2026
07:25 AM
Good morning,
I have the same problem. That's the way they work—deliberately.
07-22-2026 12:36 PM
07-22-2026 07:26 AM
Are you not able to login due to password issue?
First, please try use a browser with Incognito mode and use the Forgot email link ( https://eversafe.id.telus.com/user/forgotemail?locale=en&ForceAuth=true ) , then Forgot password link ( https://eversafe.id.telus.com/user/forgotpassword?locale=en&ForceAuth=true ) on the login page there. They will send you the "hints" to the correct email address associated.
When reset password and reattempt to login, please DO NOT use Auto-complete provided by your browser and type out the email username and password manually.
If that does not help, please open ticket with PM support
