Selecting a number
Aman24
I want a specific phone number, how do i I find if that number is available!?
Cheetah24
@Aman24: If this request is not specific to Public Mobile, you might be able to customize the number to some extent using a more bigger provider such as Rogers as indicated here; https://communityforums.rogers.com/t5/Archived-Posts/Requesting-a-specific-phone-number/td-p/445226. That doesn't mean you can find the exact phone number you are looking for; but maybe you'll have more leeway to customize the last 4 digits for example.
Moved:
hairbag1
@Aman24
log in to your account / Profile..look to the right to see your number and click the little pencil. BTW; it's highly doubtful you'll get a spectific number..you'll have to select from the pool in your area.
Chalupa_Batman
Hey @Aman24
You really can't have custom numbers but you can port over from other companies.
I'm not gonna lie. What I did is download Fongo, TextNow and played with it until I got a number I really liked. Used it for a bit cause it's free then ported it over free to Public Mobile.
