02-15-2018 06:27 AM - edited 01-05-2022 04:06 AM
I have been receiving a lot of scam calls from unassigned area codes, 1800 numbers, as well as foreign country codes in recent weeks. I have never answered to any of them.
However, I just checked my usage history to see the scam phone numbers and they don't appear. Where are they?
Finally, the history of usage only go back to January 1 2018. Like, it doesn't want to show me anything older than that. WTH is going on?
Service
02-15-2018 10:56 AM
it doesn't get recorded because you won't get charge ($ or airtime) for calls that didn't complete.
02-15-2018 07:40 AM
I think you're correct. I just called from my home line on my cell phone (and did not answer), and the usage history shows an outgoing call to my voicemail, not my home phone number.
It's so bizzare.
02-15-2018 07:34 AM
I believe the usage tracker only records completed calls. Unless you answer a call, it is not a completed call. The call log on the phone tracks all calls including missed calls. I have received a number of calls recently as well from Albania and Estonia.
02-15-2018 06:58 AM - edited 02-15-2018 07:14 AM
I've received scam calls from the following numbers in the recent days and they do not appear on my usage history:
011 355 673283014
011 355 673283013
1 (844) 259-1006
1 (800) 333-5655
The number with country code +17 and the one from an unassigned area code, I did not keep as both only called once. I assumed I could find them in my usage history but it's not there.
02-15-2018 06:52 AM
I made a phone call to my voicemail 30 min ago to try it. And my history of usage got updated 15 minutes later.
These scam calls I have received in the last 4 weeks and they do not appear.
02-15-2018 06:48 AM
@Ab555642wrote:My question is: why does those scam numbers do NOT appear in my usage history? I receive them almost every day. In the last 4 weeks, I've received phone calls with area codes from unregistered area codes, from 1(800) numbers, as well as country codes +355 and +17. None of them appear in my usage history. Why?
From my experience, the usage history does not get updated real time and has a delay, are these recent calls that were made to you that you're trying to lookup in the history?
02-15-2018 06:41 AM
02-15-2018 06:37 AM
There could be many reasons behind why you are getting these 2800 marketing calls. Did you give your number out recently when registering for something? You can either block them or change your phone number if that is an option for you.
The phone number 4385804001 shows up as a Telus voicemail access number when I looked it up, are you sure this is not you dialing to you Public Mobile's voicemail?
