04-24-2023
02:43 PM
04-24-2023
03:43 PM
computergeek541
I have a galaxy a70.
Samsung rolled out an update the other day and now I have the scrolling "no network connection" at the top. I checked....I am on my home network.
I restarted...nadda
Any ideas?
05-01-2023 06:10 PM
Problem solved.....
I pulled out the Sim again....but I let it sit for about 5 minutes. Inserted then restarted the phone
BINGO!!!!!!🥳
Thank you all for the advice and options.🤗
~Jen
04-24-2023 04:15 PM
The message center option is grayed out
There are no settings under my Sim card.
I am in good standing ....I don't understand why I have no service since the update from Samsung
04-24-2023 03:49 PM
@Tigrisnl wrote:I have a galaxy a70.
I restarted...nadda
Any ideas?
Please ensure that your SMSC is set to +16475800172,
04-24-2023 03:46 PM - edited 04-24-2023 03:47 PM
@pmva wrote:
@Tigrisnl wrote:I don’t know what those acronyms are?
Here's an article that may help. Do a network reset per @softech suggestion. If that doesn't help check this article,
Set up data on an Android phone (publicmobile.ca)
PM - Public Mobile
APN - Access Point Name
Please be aware that APN settings are unrelated to SMS text merssaging. Those settings could be set incorrectly or even just left blank and SMS would still work.
04-24-2023 03:44 PM
Still no luck
All those APN settings in the article were gone.....so I entered ad instructed
Restart
I guess I'll have to put in a request
04-24-2023 03:41 PM
Mo change
04-24-2023 03:21 PM
@Tigrisnl I assume you reboot your phone already?
Try to pull your sim card out for a minute, then put it back in and see
turn off wifi so you can check clearer if mobile connected
04-24-2023 03:17 PM
The reset did not work
04-24-2023 03:17 PM - edited 04-24-2023 03:18 PM
PM - Public Mobile
04-24-2023 03:14 PM - edited 04-24-2023 03:14 PM
@Tigrisnl try this, although yours could be slightly different due to OS version
Step 1: From the home screen, swipe up to open the menu.
Step 2: Tap Settings.
Step 3: Tap General management.
Step 4: Tap Reset.
Step 5: Tap Reset network settings. Step 6: Tap Reset settings.
Step 7: Tap Reset..
04-24-2023 03:07 PM
04-24-2023 02:49 PM
@Tigrisnl Try resetting your network settings? Did you check APN to see if values match those for PM?
