02-13-2020 12:34 PM - edited 01-05-2022 09:29 AM
Hello,
Is there anything wrong with the Access Point settings? MMS is not working, both sending and receiving. I had my data turned on when trying to use MMS, and I tried using both Public Mobile and Public Mobile 2 in the Access Point name.
Thank you so much!
02-13-2020 01:12 PM
@ntk34 Change APN Type from default to default,mms and it should work.
02-13-2020 01:12 PM - edited 02-13-2020 01:12 PM
Enable data and restart your phone and let PM SIM card to configure your APN automatically. If it fails to configure your APN automatically, manually configure APN according to previous post on this thread.
02-13-2020 12:51 PM
Set up from Public Mobile web site.
02-13-2020 12:47 PM - edited 02-13-2020 12:49 PM
@ntk34 wrote:Hello,
Thank you so much!
https://apn-canada.gishan.net/en/apn/public-mobile/samsung-galaxy-note5-cdma#com
02-13-2020 12:37 PM
@ntk34 wrote:Hello,
Thank you so much!
Using this website to edit your phone APN setting:
02-13-2020 12:35 PM
APN settings should be.
